Contact US
Dimensional tolerances as per API 653
Dear mates,
It is stated in API 653 - dimensional tolerance for plumbness (10.5.2) & for roundness (10.5.3) my doubt is about where and how many points should be measured, since there is not statement in the Std. about it.
Any input is appreciated.
RE: Dimensional tolerances as per API 653
It's everywhere. You have to find the worst place(s). You can't say it's good and then have someone walk around the tank and say it's worse over here. If you are not there to eyeball it and are just giving guidance to a crew that is on site, it could get tedious and expensive. For 10.5.2.1 you could start with measuring at the middle of each plate and at the plate vertical joints, combined with an elevation survey of the first round seam to establish tank lean (which contributes to plumbness). For 10.5.2.2 you need to examine each shell plate individually. For 10.5.2.3 depending on the tank size perhaps starting with 30 feet spacing. If I have the budget I just get a 3D scan of the entire tank, roof, floor, etc from the inside.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
