Count dimension with text after/before
Sorry everyone.
I have some problems about creating the code to count all the dimension in Catia drawing, that contain specific text (text add after or before the dimensions). Please help me.
RE: Count dimension with text after/before
Here are the code I had discovered, but I want to develope it a little bit.
1. can I select all the dimension with that specify text (in this case is FIT text)
2. Does it has any method to find dimensions with 'positioned texts'
Sub CATMain()
Dim myDrawing As DrawingDocument
On Error Resume Next
Set myDrawing = CATIA.ActiveDocument
If (Err.Number <> 0) Then
MsgBox ("A CATDrawing must be active")
Exit Sub
End If
If (InStr(myDrawing.Name, ".CATDrawing")) = 0 Then
MsgBox ("The active window must be a CATDrawing")
Exit Sub
End If
Err.Clear
On Error GoTo 0
Dim selection1 As Selection
Set selection1 = myDrawing.Selection
selection1.Clear
selection1.Search "CATDrwSearch.DrwDimension.Visibility=Shown"
For i = 1 To selection1.count
Set MyDimension = selection1.Item(i).Value
Set MyDimValue = MyDimension.GetValue
MyDimValue.GetBaultText 1, MyBefore, MyAfter, MyUpper, MyLower
Dim afr, count
afr = Right(MyAfter, 4)
If afr = " FIT" Then
count = count + 1
End If
Next
MsgBox count
End Sub
White Paper: Rapid Manufacturing with FDM
The automotive industry is increasingly turning to additive manufacturing, and fused deposition modeling (FDM) specifically, as a reliable alternative to traditional metal-cutting methods, like milling, turning and boring. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
