Purposeful Volcanic Eruptions to Control Climate
5
Here's one possibility for controlling temperature rise: https://www.upi.com/Science_News/2019/01/29/Scient...
Volcanic eruptions appear to be a significant downward temperature forcing mechanism through the expelled gases and soot blocking and absorbing sunlight. One could imagine intentionally setting off a volcanic eruption to cool the Earth.
TTFN (ta ta for now)
RE: Purposeful Volcanic Eruptions to Control Climate
ok, so we're unintentionally messing with the environment. Now you suggest that we know enough to intentionally mess with the environment.
sounds like hubris to me ...
Isn't the whole thing hubris anyway, really? Whatever side of the debate you fall on, it's hardly a secret that we're talking about a vastly complex system that we don't fully understand.
The article reads like it's been vastly simplified, honestly. While interesting, and possibly a research avenue, I can't help thinking that deliberately setting off volcanoes - or simulating doing so - is going to have a lot of other far-reaching impacts. Think of it more as another piece in the puzzle, rather than hubris or "playing God".
They always used to talk about a Nuclear winter that would occur if we ever got into a significant nuclear war.... By your argument, wouldn't it be easier just to set off a bunch of nukes in relatively uninhabited areas and expect that to cool the earth for us?
For what it's worth I partly agree with Mongrel. There is definitely some hubris in our thinking if we claim that we truly understand this complex system that is our climate.
That being said, I don't believe it takes much hubris to suggest that we understand one small aspect of that system enough to feel confident that we should be concerned about what is likely to happen in the next century or so if we continue on our current pace.
Just about every mass extinction event in the earths history has been caused by extreme volcanic events. Even some less extreme ones have led to mass starvation and death in the worlds animal and plant populations including humans.
Of course we are brilliant enough to ensure that nothing like this could be caused by human generated volcanic activity. We can always turn off the switch if it starts going too far!
If we wait a while Gaia will do the volcanic solution for us based on history.
I considered nuclear winter, which is actually where the thought started. However, nuclear winter comes with nuclear fallout; there's not much point in bringing the temperature back down but not surviving the fallout.
Not to worry, all the models show it will work :)
Where I live, an hours drive from a super volcano, there is a 200 ft thick rock layer that was volcanic ash, so I am included to ask how does one intend to turn it off once it starts, because overshooting the cooling target by couple of degrees could make global warming look pleasant.
verymadmac, exactly! Because as we all know, meddling with the natural order of things has always had such positive results. Not.
It's supposed to be a last resort scheme; there's certainly a lot of downsides and potential unintended consequences, so it would only be considered if there is an existential threat to life on Earth. One obvious issue would be just simply the magnitude of the volcanic winter; what if it drives the temperature into the regime of the polar vortex we just had, but spread out across the globe?
Quote (IRstuff)
Then the neanderthals among us will survive and overpopulation will likely cease to be a concern for some time.
Andrew H.
www.mototribology.com
If the depopulation of the Americas due to old world diseases caused a mini ice age, maybe we don't have to worry. Given the high risks of a plague of some form (infulenezia, bio weapon etc) maybe carbon emissions will fix themselves or not
https://www.theguardian.com/environment/2019/jan/3...
Build a solar shield. It isn't permanent and well within our means. It would cost in the 5-10 billion dollar range the last I read.
If you can't explain it to a six year old, you don't understand it yourself.
I think that was trillion, not billion https://www.abc.net.au/radionational/programs/scie..., which is still not necessarily outrageous. That particular approach would have required a total of 20 million rocket launches over 10 years, however, which is well beyond the industry's capacity.
To fund it you could always get it to convert the solar radiation intercepted to solar power to solve the earths energy needs.
Then you have to get it back to earth. Energy beam anyone. Then you lose control of it and cook everyone and everything!
20 million rocket launches would put a fair amount of nastiness into the atmosphere, most likely for a not-good effect.
Interesting variant on the theme, using planes to release massive amounts of SO2 to mimic the effects of volcanic eruptions:
https://www.nbcnews.com/news/us-news/grandfather-c...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Implementing a Multi-Domain System
IoT systems are multi-domain designs that often require AMS, Digital, RF, photonics and MEMS elements within the system. Tanner EDA provides an integrated, top-down design flow for IoT design that supports all these design domains. Learn more about key solutions that the Tanner design flow offers for successful IoT system design and verification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
