Contact US
Pressurized tanks
Pressurized tanks
Pressurized tanks
I have heard about pressurized tanks, I believe covered under API 650? but I have not seen widespread use in the onshore oil and gas side, especially for tank batteries and shale oil. I work mostly in the Eagle Ford. Is there a reason or some reasons that it is not commonly being used? is it one of those technologies that really work but so expensive that folks just stick with what they're used to, i.e. API 12 tanks?
Thanks for you insight.
As much as possible, do it right the first time...
RE: Pressurized tanks
IMO, it may be based on several factors, such as the process requirement, fabrication convenience, economy, etc.
API 12 is applied for the shop fabricated tank while API 650 (up to 2psi) or 620 (up to 15psi) can be used for the field erection tank.
For tank batteries, quantity has a quality all its own. Individually engineered field erected tanks have a schedule associated with them that is not generally conducive to gathering tanks based on the storage requirement per site. For storage tanks, it is more common to use some internal storage pressure to minimize evaporation losses, and may be required for emissions regulations.
API 12F tanks are an attractive option for many purchasers, as they can be a single line item purchase order. If you seek larger than the shop fabricated API 12F tanks, there are standard field erected API 12D (welded) or API 12B (bolted) solutions that may meet your needs.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
