Contact US
Information Regarding Grove G4 Gate Valve
Hello all,
I'm working on a project and require information on a Grove G4 valve. Specifically, I need some sort of reference for Cv values or a characteristic curve for this valve. Unfortunately, I have scoured the web and can't seem to find any useful resources out there. I've contacted Cameron but haven't heard back yet. I'm hoping that someone here might potentially have any sort of resources that can help me out. I'd really appreciate it!
RE: Information Regarding Grove G4 Gate Valve
This reference gives a typical full bore gate valve https://www.flowcontrol.no/wp-content/uploads/2013...
This ref has a curve and from elsewhere gate valves tend to be linear or slightly below linear, in opening percent vs CV
https://www.industrialcontrolsonline.com/training/...
Gate valves are not good control valves. Why do you need this information?
Cameron probably don't want you to use this expensive double seated valve as a control valve.
Thanks for the info! I'm performing a transient analysis of an existing pipeline and this is the model that are used as the valves at the mainline pump stations, so I'm not making any decisions on the valve selection. Note that one of the valves is just a MOV but there is one control valve of this type. I've only been supplied with the valve model and it's travel time, but I require its characteristic curve to model a sudden valve closure transient event. In the absence of data specific to this valve than I may use your information and assume they are close enough.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
