Contact US
Flow mixing valve?
Flow mixing valve?
Flow mixing valve?
Is there a valve available that will mix 75% well water with 25% rural water? Nothing based on temp…just want to have a way to control 2 water sources.
Could it be as easy as using a constant flow valve for each source and feeding to a wye valve?
RE: Flow mixing valve?
IMO, the wye valve is used to control the flow path, and can't be used to control the flow rate. To use globe valve on each feeding source to adjust the required flow before mixing at the wye valve can achieve the goal as needed.
Thanks MK
If you have stable conditions you might be able to use simple orifice pates in the two lines and just manifold them together.
If not then two control valves are much better than simple three way valve
Thanks!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
