Elements near Cohesive elements deform asymmetrically in a three point bend 2D model
Dear All,
I am modelling a 3 point bend specimen with Cohesive elements tied to the upper and lower halves of the specimen in 2d.
The problem is that the CZ elements perform properly only for a combination of element sizes, i.e. a combination of element size of structure and CZ elements, for instance in my case the structure/specimen element size is 0.2mm and CZ is 0.001 or 0.002. For any other combination the adjacent elements bend as shown in the attached image.
I will be glad if someone could explain this behaviour and the solution.
I also attach the input file.
I use full integration Plane Stress elements for the continuum part.
I tried changing
Elastic Modulus, Tie constraint position tolerance, viscous regularization, reduced integration etc.
The problem is, the cohesive strength and fracture energy calibrated for 0.2mm element size causes bending of elements when i decrease the element size.
In the attached input file I have a softer interlayer, but this problem exists even for homogeneous material model.
With regards,
Abhishek
RE: Elements near Cohesive elements deform asymmetrically in a three point bend 2D model
The only attachment is a pdf of the input file (2493 pages).
You can embed images in the message, or attach a zip file with multiple files, or just post a new message with the image attached.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
