Contact US
Toe Cold cracking of welds
Good afternoon to all,
i have a question for you. During maintanace operations of a tank, it's necessary to open a temporary door in the 1° shell course.
After 2 months that door was welded and regularly checked with RT and MT with with no defect, some toe cold cracking appeared in the horizontal seam at 2/3 mm of depth (tk plate 45mm).
What could be the causes of such defects?
Thank you
RE: Toe Cold cracking of welds
Could be resulted from the improper weld procedure or PWHT...
Suggest to have a Material Specialist to conduct a failure analysis for the weld defect.
How does one "regularly RT" the weld? - the tank was taken out of service regularly?
It would help to know the grade of steel, the product stored, the temperature of the product.
Perhaps not enough preheat and moisture was not driven off during welding, possibly low hydrogen weld consumables were not used or not kept dry. Perhaps caustic attack.
For the original weld, was the back-gouged surface of the root pass and final pass (each side) examined for its complete length by magnetic particle or liquid penetrant methods and 100% RT also?
Thank you to all for your replies, and, as you said, we think that is a problem of improper welder procedure.. cleaning weld seam, temperature maintenance during welding,moisture elimination etc etc..
I will inform you..
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
