Setting the GROUND LEVEL in STAAD Pro
Hi all,
1) Is there a way to set the ground level in STAAD Pro or is the y=0 level the permanent ground level? This is for the purpose of computing the seismic forces because, from what I know, distribution of the computed base shear per level of a structure is related to the distance of a level from the ground surface.
For example, I have to design a 4-storey steel structure. The pedestal protrudes above the ground slab by a 0.5m and in modelling the the steel structure in STAAD, the support, which is the base plate connection, is above the ground slab by 0.5m.
Let's say that the distance from the 2nd floor to the ground level is 3.3m so the distance that will be used in modelling the steel from the 2nd floor to the base plate is 2.8m.
2) Do you neglect the 0.5m distance and just proceed in the modelling and assume the base plate connection as located in the ground?
3) If yes, will this not have any effect in the seismic forces?
4) If no, what do you do for this case?
5) Do I miss something?
Sorry for the many questions. XD
Hoping to have some clarity regarding the matter.
Thank in advance everyone!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
White Paper - Moving to a Driverless Future
This white paper describes what we see as the best practices to support a sustainable engineering process for autonomous vehicle design. It exposes how to use simulation and testing in common frameworks to enable design exploration, verification and validation for the development of autonomous cars at a system, software and full-vehicle level to drive a mature product development process for automated driving. Download Now
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
