HIGH TMPERATURE ACM
HIGH TMPERATURE ACM
HIGH TMPERATURE ACM
Will ACM withstand 230°C for 24 hours?
RE: HIGH TMPERATURE ACM
Depends on the environment, but it should be ok away from moisture/acids/bases.
see https://en.wikipedia.org/wiki/Acrylic_rubber
edit - whoops, you said C not F. Dunno, probably not that hot, very few plastics can survive above 400F/200C and acrylics aren't from the family of polymers (-imides, arylates, fluorocarbons) that can survive high heat.
there is no contact with fluids
For this time and temperature ACM cn resist, but a selection of high performance antioxidant is very importante, as the curing system used, too
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Functional Prototyping Using Metal 3D Printing
Functional prototypes are a key step in product development – they give engineers a chance to test new ideas and designs while also revealing how the product will stand up to real-world use. And when it comes to functional prototypes, 3D printing is rewriting the rules of what’s possible. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
