Contact US
Heat Transfer Fluids
Good day, forum
I have an issue concerning heat transfer strategy. We have a refinery facility where some high temperature heat consumers exist - mostly reboilers. The source of heat is fired heater(s). These reboilers can be heated directly by fired heaters or remotely by one fired heater using a heat transfer fluid. Let's say only a heat transfer fluid should be consider.
Next heat transfer fluids should be considered:
- steam
- vapors organics
- liquid hydrocarbons (e.g. stright run vacuum gasoil)
- liquid organics (e.g. glycols)
- liquid inorganics
Q1: Can one share worth links to a discussion with pros and cons different types of heat transfer fluids?
Q2: Can one share list of heat transfer fluids with short desctription and properties?
Q3: Can one share own experience in heat transfer fluids design/operation.
RE: Heat Transfer Fluids
You seem to want all of your work to be done by others .....
Are you aware of a wonderful search device called GOOGLE ????
MJCronin
Sr. Process Engineer
A few pointers that may help with the choice of HTF:
a) Minimum HSE handling issues, reduced toxicity, reduced volatility
b) Good heat transfer characteristics and high Cp
c) Keep MTD as low as practically possible at reboilers to reduce salt deposition /scaling on process side of tubes due to high film temperatures.
d) Keep HTF pressure higher than process side in order to prevent cross contamination of HTF / foul up HTF furnace firetubes with process side fluids at HXs' that may leak in future.
As with many other choices one makes in life, so it is with processes and equipment also: choose to maximise on advantages and minimise risks and compromises.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
