Automated Screw Processes Basics
Does someone has some training material on the different automated screw processes?
In particular, I am looking for some basics on the torque and angle, as well as the gradient screw process.
What I found googling was not relaly what I was looking for...
RE: Automated Screw Processes Basics
If I were you I'd get into contact with someone like Atlas Copco that sells the automated equipment that puts this theory to use- they will have all sorts of reading material for you.
Get a copy of Bickford's book and read it well. This is a very deep subject and there a many subtle things that can cause all sorts of unexpected results.
Depending on the methods ball valve manufacturers use to determine their published rated flow capacities, the resulting value may be different, even for virtually identical valves. The rated flow capacity of a valve is typically expressed in terms of some type of flow coefficient, currently usually, Cv and Kv. They are equivalent but differ in value due to the units for flow rate and pressure they are associated with.
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
