computer simulation of behaviour of soil
Hi ,
May I ask when you have a ground material that is a normally consolidated that will be need to be loaded by the foundations of a building that is sensitive to settlement what would be the most important considerations one must consider for a computer simulation?
Thank you
RE: computer simulation of behaviour of soil
I might be wrong, but the use of a computer program only is needed for extensive calculations, such as calculating possible settlement. In my case spreadsheets do the job nicely. Input need is the lab compression dimension relationships, loads as well as foundation elevation and size ranges. Thus each is important, but some parts can be estimates, as a start. In other words you need several important inputs.
The most important consideration is to have an experienced geotechnical engineer to review the results of computer simulation on settlements.
The first stage of site investigation is desktop and it informs the engineer of the anticipated subsurface conditions. By precluding the site investigation the design engineer cannot accept any responsibility for providing a safe and economical design.
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
