Contact US
flow curve on a pressure relief valve
lets say you have a PRV set at 100 psig and at that pressure setting the valve has a max flow capacity of 10,000 GPM
at 10% overpressure the valve is in full lift and has a max flow rate of 10,000 GPM
I am looking for a flow chart (curve) that shows the capacity in proportion to valve lift.
example; valve inlet pressure reaches 105 psig what is the flow rate?
RE: flow curve on a pressure relief valve
For typical conventional safety relief valves, there is very little flow before the relief pressure (set pressure + overpressure). You'll have the seat rise slightly, which will result in simmering/leakage. As pressure reaches the the relief pressure, it quickly opens. To my knowledge, you cannot take credit for or assume reduced flow for something less than the relief pressure.
Note some relief valves, such as pilot operated, have very low leakage even very close to the relief pressure.
MSPVIN
When asking a detailed technical question about matters that under normal circumstances are without importance, there is most often a special working situation or problem behind. If you detailed, you could perhaps get a beter answer.
As RVAmeche explains, pilot operaated SRV valves are very precise, while spring type SRV's can vary regarding accuracy, and more easily give premature leakages, uncompleted lifts and even 'simmering, banging' repeated small lifts in series, which in all cases would be difficult to give accurate teorethical flow descriptions.
Figueres can however be given if this, for instance, is a disc valve, (centric or excentric) weight, and/or hydraulic damped type, built for relief, damping and reducing flow.
Answers are best given by producers of original or replacement types.
Good luck!
It's 10000 GPM.
Perhaps this explanation might help http://www.valvemagazine.com/magazine/sections/bac...
Relief valves are designed to "pop" open and flow of the fluid helps to keep them at full opening. If a relief valve opens and the flow is maintained at the same pressure then the valve stays open.
The 10% is the maximum "accumulation" the protected vessel or pipe can see to take account of losses in the inlet piping, the valve and the outlet piping when flowing at maximum relief flow.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
