Pump Mechanical Seal: Single Seal vs Double Seal for Toxic Process Fluid
Hi guys,
When the process fluid is specified as TOXIC in the data sheet, it is required to use Dual Mechanical Seals? Could you explain the degree of toxicity of the process fluid for it to require dual seals rather than just a single seal.
Currently I am working on data sheets where it currently specified Single cartridge Mechanical seal but the process fluid is also specified as toxic.
Thanks!
Virata
RE: Pump Mechanical Seal: Single Seal vs Double Seal for Toxic Process Fluid
not being a mech seal expert, actually knowing very little about applications outside of pumping water - for toxic I would go with double mech. seal with barrier fluid between.
Automotive antifreeze is toxic. Methanol is toxic. In high concentrations, Vitamin D is toxic. Just saying that the fluid is toxic is not sufficient to understand the risk of a release. Knowing only that a datasheet lists the fluid as toxic is not enough for me to make a recommendation for the seal configuration.
Johnny Pellin
Would a mag drive pump be acceptable for this service?
Toxic is not the same as "lethal" in B 31.3 and as said, doesn't give you much to go on.
you really need to talk with someone from Tech safety to establish what is required.
API seal flush plans you can select from are plans 52A and B, and plan 53. Also note that driver speed turndown range, volatility and viscosity range of the process fluid have some bearing on the plan selected. Talk to the rotating machinery specialists and process safety engineers in you company to see which ones are suitable. A generic solution to a particular service application subset would be ideal, but not always possible.
Thanks guys. I will coordinate with tech people and see what I can do.
RVAmeche - We currently looking at API 610 pumps only.
Many specifications within companies will drive a toxicity rating that will lead the required specification of the machinery, seals and protective systems.
Magnetically driven seal less pumps, or Magdrive pumps are often an excellent choice for toxic fluid, and offer a sizable benefit on through life costs in application.
If the fluid is below 200cP, less than 260C and with a solids content below 2-5% by weight and 150micron particle size then a magnetically driven centrifugal pump should be considered.
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
