Maximum allowable tank diameter and height for Biocide Tanks
Dear All,
I have to change a Tank design (fluid is Biocide) from 3 m3 (792 Gallon) to 0,4 m3 (106 Gallon).
My questions:
1.- How to set the relation of a maximum allowable tank diameter and height?
2.- Is there any standard to cover that relation ?.
I think API 650 doesn't cover those relation.
Best Regards
My questions:
Best Regards
RE: Maximum allowable tank diameter and height for Biocide Tanks
0.4 M3 is a very small volume to bother with details like this.
If you really want a vertical cylindrical tank/ pipe then 3:1 h/d would be reasonable.
You COULD check for wind and seismic overturning per ASCE 7 and applicable building codes, and adjust dimensions accordingly. Sliding when empty may require anchorage regardless of dimensions.
MJCronin
Sr. Process Engineer
