creating an true involute gear in solid edge
svt1234
Automotive
I have used the gear module in solid edge and it does not work well for reverse engineering (what i do). does anyone have a way to draw the curve? all of the web based generators i found use metric module, I use mainly DP. I used to create using a LISP in autocad but my Autocad is gone now.
