Code for Full-Port Ball Valve
Hi All,
We have a ball valve supplier explain to us the other day about the ambiguity on "full-port ball valves". There is a standard regarding port size on gate, globe, and check, but not ball valves (apparently). This was their explanation that allows them to supply a ball valve with ID 1.5" for a 2" line.
Since I'm fairly new in the process piping industry, I figure I could find out where I could find the specs on this, or if there even is one.
Before you ask, yes I searched other threads, but I wasn't able to find any that mentioned and code or specifications.
RE: Code for Full-Port Ball Valve
I am also of the opinion that it's not exactly full-port. These valves are also drain service valves, which leads me to think that this is sort of a non-issue.
For the valve supplier you have, what does their catalog say regarding the valve bore? Definitely not full port (or full bore...terms are interchangeable).
API6D and API 608 both specifie the same full bore size : 49mm (1.94 inches) for a 2'' valve, (might be a little less for class2500 and above).
of ASME B16.34
Some Manufacturers on Small High Pressure Floating Ball Valves will try to match the Valve Bore to the Mating Pipe Schedule Bore, some state 'Valve Bore to suit Schedule 160 Pipe'.
The whole issue revolves around what the Pressure Class is and what Specifications the End Customer is calling up, to a degree if the Valve is Floating Ball or Trunnion Mounted.
Its always been a contentious issue and still is...
