CC/REV question
rusowner
Automotive
I am new into pumps so my question might sound not professional but, I need to get around 50ml/minute flow by utilizing gear pump. Do I better go for 5cc/rev pump and use 10 RPM motor or is it better to have 1 cc/rev or even lower and use more RPM?
And another question, what pump would you suggest for such a low flow rates?
You really need to search on either "dosing pumps" or "metering pumps"
You find things like
A lot depends on how accurate you need to be and how much money you have to spend.
In general though it is easier to control a reasonable speed so more RPM is better.
