Contact US
How to select the required capacity of filling pump for Water storage tanks (Reservoir)
thread1452-412042: 1st ring shell replacement
How to choose the required capacity of water filling pump & Size of pipes. The tank details are: Dia-102 Mtr, Height-19.3Mtr, Thickness of Bottom Plate- 8 MM, Annular Plate-20MM. Water storage point is 500 Mtr distance from the Tank.
Plate Material Thickness
Bottom A283-C 8.0
Annular A537-2 20.0
Shell (1) A537-2 42.0
Shell (2) A537-2 41.0
Shell (3) A537-2 29.0
Shell (4) A537-2 25.0
Shell (5) A537-2 19.0
Shell (6) A537-2 14.0
Shell (7) A516-70 11.0
Shell (8) A516-70 10.0
Roof A283-C 6.0
RE: How to select the required capacity of filling pump for Water storage tanks (Reservoir)
Errr, you need to know how much water flow or volume you want in a specified time.
That's one big tank you have there, but you could want to fill it in an hour ( unlikely), a day, a week, a month - totally up to you.
the materials of the shell and roof in this instance are irrelevant
With API oil tanks, they are normally hydrotested with water, and the source of water, and the speed at which it may be furnished, is always a concern.
But with water tanks, usually, the hydrotest is conducted at the same time they are put into service.
Also, petroleum tanks with an internal lining are usually hydrotested prior to lining. Water tanks are more commonly hydrotested after lining, which can collapse the schedule a bit- assuming this is the same tank as in your previous post.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
