Contact US
PRV spring range
PRV spring range
PRV spring range
Hi Valve expert,
I currently reviewing relief valve calculation from vendor. as per my understanding the spring range should be at least +/-5% of set pressure or at least the set pressure is within the spring range. what would be the effect if the minimum or maximum value of the spring is equal to the set pressure? is there any written guideline on what should be the minimum/maximum tolerance on the spring range?
thanks in advance.
RE: PRV spring range
For a relief valve to be set at a pressure which is on the higher side for the given spring range, the spring is comparatively soft for the given set pressure load. This can cause the valve to achieve an early lift and longer blow down. Conversely if the spring is comparatively stiff, the valve might have shorter lift and short blow down. The tolerance of the spring is calculated accordingly. As long as the set pressure falls inside the spring tolerance this does not a matter.
ASME relief valves come with a certified set pressure and flow capacity. As long as these values meet your needs, I wouldn't worry about the spring tolerances too much.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
