Contact US
API 653 Hop Tap for 8" nozzle
Dear Sir.
Does anyone coult tell me if, for a tank of dia x H = 27.625' (liquid hight 20.8'), we can performance a hop tap of 8" nozzle having a shell average meassured thickness of 0.208". I know that API 653 require a minimum thickness of 1/4" but the shell plate required by calculation, using A283C plates and E = 0.7, is 0.1472".
In case that we can not performance the hot tap procedure I would apprciate any alternative to place in the tank a 8" nozzles without empty the thank
Thank for your help
RE: API 653 Hop Tap for 8" nozzle
As you note, API 653 calls for a minimum shell thickness greater than yours.
Possible options:
Don't comply with API 653
Hot tap two 6" nozzles and pipe them together
Hot tap a shell manway cover plate with an 8" nozzle, if the cover plate is 1/4" or more
Sometimes you must empty the tank ....
No spare empty tank available ? ...... Discuss this with the plant manager and the process engineer, perhaps this could be a future enhancement.
Suggest that you consider the modified shell manway cover plate fix. You can have a replacement made in the shop and ready to swap out during a brief shutdown
MJCronin
Sr. Process Engineer
Is the required minimum thickness the concern of the burn through during the hot tap?
Check with your plant Material Engineer to see if it helps to add a butter weld layer on the pipe for the hot tap connection.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
