Catia Disassembly (GSD)
I used a sketch to create a simply soccer free kick wall:
Than, I used GSD Disassembly on the sketch and created three different zones.
The problem that I encounter is that the lines created from the sketch are not linked, so if I modify the geometry of the sketch, the lines will not follow.
Is there another tool (instead of Disassembly) that keeps link with the sketch?
CAD 2015
RE: Catia Disassembly (GSD)
you could use the OUTPUT profile function in the sketch, this will keep associativity with sketch geometry.
Eric N.
Itsmyjob,
Thanks a lot!
Beatus, qui prodest, quibus potest!
2thumbsup
CAD 2015
thanks for the comment
Eric N.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
