Contact US
Weld strength verification required?
Hi everybody,
Is it required to check the strength of the welds, per paragraph 5.7.2, for shell nozzles when they comply with the figures an tables of API650?
RE: Weld strength verification required?
Generally, if you use the standard details from the tables, it is not necessary to check weld capacities.
Not necessary as in "i don't suspect any problems" or in " it is not required by the API"?
Is it possible to refer to a paragraph in the code?
THX
Not necessary as in "having previously checked this, it is not the limiting factor for a standard nozzle".
Note that API-650 does allow variations in repad size, shape, thickness, etc., and I expect you'd be most likely to run into weld issues either using repads thicker than the shell or outer fillet welds smaller than the repad thickness.
If in doubt, do the check for the tank in question. It lends itself to a spreadsheet design.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
