HEC-HMS Error Numbers
Has anyone came across a listing/index of HEC-HMS error numbers with an associated description/casue?
I am having an issue with a model I've been working on and I keep getting "error number 11" and I can't determine the issue.
ERROR: Error in computing storage-outflow for Upper Lake
Function: ReservoirCapacity; Error number: 11
Any help is greatly appreciated.
RE: HEC-HMS Error Numbers
In my Elevation-area function for the reservoir, the storage is defined down to a certain elevation (an elevation below that of the "initial elevation" setting of the reservoir). When I attempt to run it I am getting the following error:
However, when I delete the Elevation-Area data below the "initial elevation" setting of the reservoir, the model runs fine. Any idea what could be causing this? Obviously, the program should allow storage to be defined below the "initial elevation" right?
Any insight is greatly appreciated.
