LPG / Natural Gas Spilt Control system
Dear Group
In our plant we already use LPG for complex flare system to ethylene plant, polyethylene and polypropylene plant, since we have a shortage of LPG we decide to use in parallel N.G ( size 16") to feed flare-pilots by design new pipeline connected to all F. pilots data of the N.G are :
proposed Pipeline Size: 2"
pressure : 16 kg/cm2
flow : 43 nm/hr3
temp: 20 C
Q1.Is it necessary to attached a flow meter for Flare-pilot pipeline? API537 dose not illustrated whether or not ?
2. another issue to connect the N.G line to ethylene plant to feed fuel for furnaces, where already there is a control loop controlling LPG fuel flow by using foxboro pneumatic pressure controller with ( 2-output)to control valve feeding LPG.
Q2. can I use the second foxboro controller output to control the new loop for N.G flow to furnaces, or i have to use another controller?
RE: LPG / Natural Gas Spilt Control system
IMO, the requirement of the flow meter on the fuel gas line is the operation and process safety issue. Consider to conduct a PHA/HAZOP with the right people involved to determine the flow meter requirement for both questions you have.
Q1. In many oil and gas companies, it is customary practice to keep track of and report CO2 and other greenhouse gas emissions. If this practice is active in your plant, then it is likely that Operations staff would insist on a pilot gas flow meter here.
Q2. Process controls for fuel gas feed to furnaces can be complicated, there may be controllers to control air /fuel ratio, another for max set PC and yet another for min set control. Talk to the controls engineers responsible for these control loops at these furnaces before you scavenge any PC here for flare pilot gas pressure control.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Understanding Critical Specifications for Dynamic Metrology Applications
Different types of metrology have different critical specifications to consider when determining which actuator technology to use. This white paper goes into detail on the demands of dynamic metrology applications as they apply to the selection of precision linear motion control components and systems. In addition, the relevance of Moore's Law is examined in the context of the industry. Download Now
White Paper - Permanent Non-Welded and Cold Bent Piping Solutions
Commonly used welded piping connections come with skilled labor, validation, inspection, and long commissioning times, as well as the workplace hazards associated with welding. Non-welded permanent mechanically attached fittings offer a viable alternative to welded piping systems that greatly reduces the time to commission piping systems through reductions in many of the time-consuming steps required in welding. Download Now
White Paper - Take Mobile Hydraulic Systems to a New Level
The introduction of digital ecosystems connecting electronic control hardware and software to the Cloud is catalyzing a new era of mobile machine and equipment design innovation. This is enabling OEMs across industries to develop customized solutions that digitally integrate hydraulic and machine controls with the Internet of Things (IoT). Download Now
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
