sweep mesh in circular partition around crack tip- Abaqus
Hi
Wish you all happy new year!
I am new here, I hope you can help me with my question: see the attachment, please
The partition around the crack tip is circular divided in 4 quarters. I want to sweep the mesh through the depth and keep it as it is in the circumference direction. this part is independent in an assembly.
As it has seam crack it cannot mesh with the bottom-up method.
tried hex-dominated & sweep mesh control. assigned the path and the stack direction. however, I still get the triangular element in the generated mesh. which ends with errors as it is not allowed to have tet element in the crack control region.
tried different meshing scenario sometimes ends with one crack tip partition has the wanted mesh but the other one has not even though I assigned same mesh control.
Thanks for your time
RE: sweep mesh in circular partition around crack tip- Abaqus
is the issue that the mesh isn't uniform through the thickness ? have you tried to mesh each curve associated with the solids ?
rb1957
Thanks for your comments
Yes, I wanted the mesh to sweep through thickness. otherwise you got a triangle elements which are prohibited (Error) in the contour region.
The issue solved by creating another partition (yellow lines in the attache) around the core (cylindrical partition) around the tip, then seed the edge of the new partition same number of elements as the one at the tip.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
