pump selection for spray nozzles
Dears,
I would like to select pump for some spray nozzles of dust suppression.
inlet water of nozzles should have below specification:
- Q = 3.8 lit/min
- P = 4 bar
Which type of pump do you propose for this specification?
RE: pump selection for spray nozzles
A small one.
A little centrifugal type pump would appear to be the simplest and cheapest pump.
Just search small water pump 4l/min.
e.g. https://www.amazon.co.uk/100PSI-PRESSURE-DIAPHRAGM...
small units ight not be suitable for constant running so talk to the supplier.
3.8 l/m total or each nozzle?
White Paper: Industrial Control Basics: Contactors
A contactor is an electrical device used for switching an electrical circuit on or off. Considered to be a special type of relay, contactors are used in applications with higher current carrying capacity, while relays are used for lower current applications. Download Now
Research Report: State of IoT Adoption in Product Development 2019
This research report, based on a survey of 234 product development professionals, examines the current state of Internet of Things (IoT) adoption by product design teams, its perceived importance, and what features and capabilities teams consider important when making decision about adding IoT functionality to their products. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
