Yes, hearing "flow makes it go" winds up my integrator.
I have been trying to make "flow makes it go" go away for 20 years on various forums.
I take delight in rubbing in the fact that Newton did not include flow in his 3 laws of motion.
Have you considered extending the depth of some of Mr. Johnson's original articles, particularly on modeling?
Very good question.
Jack Johnson is leaving his post because he wants to spend more time he want to spend more time on modeling pumps, motors and valves. Jack has written many articles where he lays out a model of a motor or pump that looks like an electrical circuit. This makes sense, Jack's background is electrical. However, what is the reader going to do with that article? There is a recent JJ articles on modeling motors. Was it useful? This is the problem.
In the past Jack has wanted me to get involved with a committee to standardize models. I think it is a good idea but the reality is that if there was a good model of a motor, what would you do with it? I think, what would I do with it? Do you need to know about the case drain and how much oil leaks across port A to B etc? People have been "getting by" for decades now. I saw an article that defined 5 levels of details for pumps. I would prefer to keep the models relatively simple. I don't want perfection to get in the way of the good.
Here is what could be done. If I had flow meters for the inlet, outlet and case drain, pressure sensors on the A and B ports of the motor and encoder to measure the speed and finally a dynamometer, I can model the motor very thoroughly. It requires solving many differential equations simultaneously and finding the coefficients to those differential equations. I know how to do that. I just don't have the equipment but if I did, then what? It is clear that few understand Laplace transforms and fewer yet would understand systems of non-linear differential equations. Who would supply the data for modeling the pumps?
What to do?
Another thing I would do is define some python standard classes ( actual I have ) for valves, cylinders, pumps. I chose python because it is free and very capable like Matlab. Would the big companies follow my lead or do their own in some other language and sell their simulator? BTW, don't be surprised if some python code shows up in the articles. How many people know python?
I know that Jack Johnson would really like to make progress on this topic which is why he is letting me take his place. I wish him luck but I don't see how one can herd cats ( big hydraulic companies ).
Since I know IRstuff knows Mathcad I will provide this link.
I use this file as a starting point for doing simulations for customers.
How many people would understand what is going on there.
Peter Nachtwey
Delta Computer Systems
