Change Excel paper size
Hello everyone,
I'm working on VBA CATIA project, that need to be connected with Excel to save Data, and I do have to adjust the page size to A4 or A3 depend on the result of OptionButtons (pict bellow ), I tried this code but I got this error message "Run Time error 1004" 'impossible to define the property of PaperSize
CODE --> vba
Private Sub OptionButton1_Click()
If OptionButton1.Value = True Then
With AppliExcel.ActiveSheet.PageSetup
       .PaperSize = xlPaperA4
End With
AppliExcel.Application.PrintCommunication = True
AppliExcel.ActiveWindow.View = xlPageLayoutView
End If
End Sub
Private Sub OptionButton2_Click()
If OptionButton2.Value = True Then
       .PaperSize = xlPaperA3
End With
End If
End Sub
Public AppliExcel As Object
Private Sub UserForm_Initialize()
Set AppliExcel = CreateObject("Excel.Application")
AppliExcel.Visible = True
AppliExcel.Workbooks.Add
End Sub
Does anyone have any suggestions what wrong it is?
Thanks in advance for any suggestions
regards,
RE: Change Excel paper size
replace
with
With CATIA.ActiveDocument.ActiveSheet.PageSetup
Eric N.
Hi, itsmyjob
Thank you for your response,
I tried your suggestion but its still not working, I got this error message " Automation error ",
I'm launching Excel from CATIA, and I need to set the excel page size to A4 or A3 as mentioned above
regards,
I've tried this :
'******My Main Code
CODE --> VBA
Public optionA4 as boolean
Public optionA3 as boolean
Sub CATMain()
dim AppliExcel As Object
UserForm1.Show
If OptionA4 = True Then
   AppliExcel.ActiveSheet.PageSetup.PaperSize = xlPaperA4
End If
If OptionA3 = True Then
   AppliExcel.ActiveSheet.PageSetup.PaperSize = xlPaperA3
End If
End Sub
'***for the userform
CODE --> VBA
  optionA4 = True
  Unload UserForm1
End If
End Sub
  optionA3 = True
  Unload UserForm1
End If
End Sub
ferdo :
I've already checked the microsoft docs,I used the same in my code but I still get the same error, for the Yellow line :
Unable to set the PaperSize property of the PageSetup class
and also I get this error on the orange line : Application-defined or object-defined error
regards,
Thanks everyone I resolved the problem by replacing xlPaperA4 with the number 9 and xlPaperA3 with 8, and xlPageLayoutView with 3
For this reply,I just wanna share with you my solution, it works well now
regards,
LWolf
thank you for your kind information,I really appreciate it;
have a good day,
regards,
KABEL
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
