Contact US
How to Rectify Distortion of Annular Plates in Double Wall Ammonia Storage Tank
We are constructing a double wall ammonia storage tank. Annular plates 12 mm were laid down and welded from both sides. After completion of annular ring 4 no of base plates 18" x 12" x 12 mm (for strap connection) were welded on each annular plate each using 4 fillet weld passes. Now problem is we are facing permanent distortion (i.e. annular ring lifted upward from inside) of maximum 4 inches from bottom. Expert opinion is required to rectify this issue.
We have installed Z type temporary anchors to pull back distorted plates to their position until inner shell is placed on annular plates (at the center approximately). This is because we are hoping that once inner shell load is placed distortion will be compensated but if not then what should we do?
Immediate response will be highly helpful.
Some pics are attached for understanding.
RE: How to Rectify Distortion of Annular Plates in Double Wall Ammonia Storage Tank
Dear Khasaq,
Did you come up with a solution?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
