rust-proofing tapped holes
5
I have tapped holes 1/4-20 in steel that are getting rusty. Apparently the supplier cant Zn plate because they are blind and it's an air lock. One thought was to put stainless inserts. But is there a good product that can be applied to prevent rust?
RE: rust-proofing tapped holes
Oil or grease are pretty effective. Be careful with grease in a blind hole. You can crack steel with the hydraulic pressure created by the screw compressing trapped grease. There are also greases designed to protect electrical connections from corrosion that contain zinc powder.
There are oils that have rust preventatives in them, RP oils.
Contact someone like CorrTech or Edco.
I'm a big fan of anti-seize.
A low strength thread locker might work too.
How permanent of a solution are we looking for here? Grease packed in the holes is standard practice to keep them from rusting until delivery. If it needs to last the life of the item, consider using a plug.
Hi Chopper
Have you considered putting a small pilot drill hole through prior to drilling and tapping the hole, that way the hole isn't blind anymore and plating might be an option.
It’s not just a question of appearances. If untreated rust can completely decimate an entire structure.
If this is only a concern while the part is in transit or stored prior to use, have the supplier but wooden golf tees or the soft foam disposable ear plugs in place
I wouldn't grease the threads without figuring out the impact to the applied torque on the mating fastener
If you where to plate the holes then likely you would have to be machining them oversize to compensate for the coating, else you would be breaking bolts and or not starting them.
It depends on the shelf life as to what kind of oil or rust preventative to use.
Candle wax. I once used this in an emergency and it worked. These were bees wax candles that came from an old church.
Let's not overthink this. How about putting a piece tape over the holes? You know, the good stuff like a little circle of FEP tape or something.
I'm a big fan of Loctite PST applied to the male threads.
Mike Halloran
Stratford, CT, USA
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
