ASME PCC-1 Appendix O Calculations 1
doct9960
CA
Are there plans to add the ASME PCC-1 Appendix O calculations in Compress?
Thanks!
It will be quite a while before my company "approves" the new Build for official use so I created my own worksheet (still in progress). I am glad I started to create the worksheet. Compress just had input boxes for the maximum permissible bolt stress prior to flange damage (Sfmax)and single flange rotation (Theta-fmax). The Compress user needs to calculate Sfmax using the equations in WRC 538 or find out through FEA. Same thing with flange rotation which I tried calculating using EN 1591-1. Do you know if ASME has guidelines for calculating flange rotation?
@doct9960
With regards to calculating rotation of flange, the rigidity factor formula in ASME VIII Table 2-14 can be modified to do just this. By simply removing the K factor the result will be rotation in degrees.
So in essence, ASME VIII rigidity limits rotation on integral flanges to 0.3 degrees and rotation on loose-type flanges to 0.2 degrees. This is obviously based on allowable bolt stress however and in the real world the rotation will be higher than this.
For PCC-1 Appendix O, we typically limit flange rotation to 1 degree for spiral wound (and similar materials).
