Block W block
sudhakarn
Automotive
IN
I want to understand the difference between block and Wblock.Both can be inserted through design centre.
Please clarify.
On the command line, "Block" creates a block in the drawing while WBlock creates a block on your hard drive and optionally leaves a copy in your drawing. WBlock is an abbreviation for WriteBlock. I'm not sure what happens in the Design Center.
Thank you IfR.Awaiting more replies on this.
