Contact US
Multiple nozzle desuperheater valve - Pressure drop and weber number.
Hi all , We have the boiler desuperheater control by Multiple nozzle desuperheater valve. I got a offer from two reupted supplier. Below are some details on design case.
Spray flow : 3,11tph
Spec density : 0,95
Cv @ 80% opening : 6,78
Dp offered : 0,3 bar
On the above i calcualted the DP , it was around 0.2 bar. Below are some opinions needed.
1, Both the suppliers give DP across the load same 0,3bar but with different CV --> My view is Different Cv (different opening) results in different DP in principle. May be they specify the max 0.3 bar in all load cases.
2, Interesting for me : this kind of valve (multiple nozzle) suppliers requires atleast 5 bar above the steam line. I was under impression 5 bar will the DP across the multiple nozzle valve. When they have 0,3bar DP across then why do they every time require 5 bar DP atleast?
3, I read somewhere , weber number is the indication of atomization and it needs to be above 12. Does anybody have calcualtion (Dr google is not much helpfull this time) of weber number?
PS : i will be posting this in Boiler group.
Appreciate you opinions.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
