Contact US
Expierencing pink water in our sodi
Expierencing pink water in our sodium hypo generation system after receiving a batch of salt. I have been looking to see if anyone else has had this problem but can never find a answer or solution to the problem.
RE: Expierencing pink water in our sodi
It seems to shed the pink color off the cells after it's done generating
Did you ever find a conclusion to what was causing the problem?
Most likely the pink came from the pink thread seal tape.
Otherwise no.
Ashtree
"Any water can be made potable if you filter it through enough money"
We went through our fittings and found that our salt delivery line that is stainless may have not been welded with stainless causing corrosion to blow through with the salt delivery
Did you test Fe levels?
There are a few other impurities that will add color, but Fe is a good first guess.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
