Ball Valves Material Compatibility
Hi Guys -
I currently have a floating ball valve that operates in a Mono Ethylene Glycol (MEG) Regeneration Package. The piping spec that it is on is B1E (Carbon Steel, Pressure Class 300, Corrosion Allowance 3mm). I would like to replace it with a new design and am stuck with two options. If you can help me identify which one would be the best option and why. Appreciate your help.
Current Design
Design Standard: API 6D / API 608
Body Material: CS - ASTM A216 WCB
Valve Dim/Pattern: ASME B16.10 (Long)
Ball Material: 316 SS
Stem Material:316 SS
Seat Material:316 SS
Seat Seal: RPTFE
Stem Seal: RPTFE
Body Seal: RPTFE
Port/Bore; Full Bore
Shell: API 598 / API 60
FireSafe Design: API 6FA / API 607
Option #1 Graphite Seat
Design Standard: EB12 ASME B16.34
Ball Material: CF8M
Stem Material: B29SS
Seat Material: Graphite
Seat Seal: Graphite
Stem Seal: Graphite
Body Seal: Graphite
Shell: API 598
FireSafe Design: API 607
Option #2 Metal Seat
Ball Material: 431 SS w coating
Stem Material: 431 SS
Seat Material: 431 SS
Seat Seal: Metal
Stem Seal: Grafoil
Body Seal: AS2637 - 630
Shell: MSS SP61
Current Design
Seat Seal: RPTFE
Stem Seal: RPTFE
Body Seal: RPTFE
Ball Material: CF8M
Seat Seal: Graphite
Stem Seal: Graphite
Body Seal: Graphite
Shell: API 598
Seat Seal: Metal
Stem Seal: Grafoil
Shell: MSS SP61
