How To Spec Pumps?
How To Spec Pumps?
How To Spec Pumps?
Hello everyone.
I am about to be involved in a project which involves specifying pumps for a refined product terminal center. These would be feed / discharge pumps for API tanks. Being new to this I've been doing research on this. Besides NPSH and power requirement calculation. What other basic specifications must I look into and be aware off?
RE: How To Spec Pumps?
Forgot to add that I been reading API 610. So, what I am really seeking is mostly recommendations from personal experience.
Typically your organization will have previous specs to use as a starting point, assuming they've done similar projects in the past. You'll of course update them accordingly for the service, flow/pressure requirements, connection sizes/ratings, and desired features.
If you are new to the business it might be worth having a look at a few installations and talk to people who supply , install, operate and maintain such pumps. They may have some special insights which will help you develop the specification.
Ashtree
"Any water can be made potable if you filter it through enough money"
Close Box
Join Eng-Tips® Today!
Join Us             Close
