IDF Curves and Time of Concentration
To someone who can help.
Typically if a IDF curve is provided for a site is it typically not necessary to calculate time of concentration since the IDF curve gives intensities? Or is time of concentration still necessary?
RE: IDF Curves and Time of Concentration
Peter Smart
HydroCAD Software
www.hydrocad.net
Instead, an IDF curve shows the predicted relationship between Duration (=Time & =Time of Concentration) and Intensity (i.e. average rainfall intensity over the Duration in question). Also, Tc is the independent variable and I is the dependent variable. This relationship between Duration and Intensity is derived using actual precipitation data and statistics. An IDF chart typically includes multiple IDF curves to cover a range of rainfall probabilities (e.g. 2-yr, 10-yr, 25-yr, etc. events, representing annual probabilities of occurrence of 0.50, 0.10, 0.04, etc.).
For applying the Rational Method, we make Tc equal to Duration. So, to get the Intensity (typically inches per hour or millimeters per hour), you must first estimate Tc (typically minutes). There are many methods for estimating Tc. One of my hydrology books lists seven different methods for estimating Tc and I have seen several more that aren't in the book. The simplest method I know of is the Kirpich Equation, which requires knowing only the length and height of the watershed. However, its simplicity is also its weakness because there is more to a watershed than just its length and height. Other equations require more information about the watershed, such as average Runoff Coefficient, etc. Actually, the entire Rational Method is weak (that's another story), but it's also extremely useful.
For one site I recently worked on, the equation for the 2-year IDF curve is I2 = 3.13 * Tc^(-0.49) and the equation for the 10-year IDF curve is I10 = 5.86 * Tc^(-0.49). Please note that the family of IDF curves for a single site will have the same exponent and the IDF curve will plot as parallel lines on a log-log chart. So for a 2-year event, Tc = 10 min results in I = 1.01 in/hr, while Tc = 20 min results in I = 0.72 in/hr.
BTW, I derived the above equations from a paper chart by manually scaling two points on each IDF curve, then doing a power curve regression using my HP-42S calculator.
I hope this helps.
--Winston S. Churchill
The time of concentration is determined based on watershed characteristics. In my jurisdiction two methods are recommended based on size of watershed.
Those things are input into hydrology and hydraulic software which uses design storm distributions and rain on snow events. The software is then used to provide peak flows or storage requirements to size a pond, ditch, or sewer.
