Multiple proposal requests
4
Just came across this situation:
You are an engineer and a contractor/supplier calls and asks for a proposal to do a study of a roof supporting mechanical equipment at a remote facility.
You provide the proposal to the contractor, they sign it, and you travel to the site, perform the investigation, and meet the owners of the facility.
The investigation is completed - no problems.
The next step is that, due to the investigation showing that the units don't belong on the roof, the contractor then asks you for a second proposal to design a separate structure to support the equipment off the roof. You provide them with the proposal.
The contractor is also, in tandem with your second proposal, submitting a proposal to the owner that includes selling them new equipment as well as providing the structure for it (my proposal) marked up a bit.
Then nothing happens for a while....
The owner then calls you, the engineer, for a second proposal to design the separate structure, independent of the contractor.
Ethical issues and points:
1. Your relationship to the owner was only possible due to the contractor bringing you on board and introducing you.
2. You have an outstanding proposal to do the design of the structure pending in the contractor's hands.
3. The owner is deciding to not deal with a Design/Build approach but rather going directly to you the engineer to set up a Design-Bid-Build approach, bypassing the contractor.
4. The owner intends to let the contractor bid your design...just not as a Design/Build entity.
Optional responses (which one?)
1. Simply give the owner a new proposal since the contractor has not signed your first proposal.
2. Don't give the owner a proposal, explaining that you already are working as a team for the contractor.
3. Call the contractor and explain that you were called by the owner and asked to provide a proposal and intend to do so.
RE: Multiple proposal requests
Honestly it would depend on my relationship with the contractor. If there's a solid working relationship, I'd give him a call and discuss. It may end up working out to be a wash for them in terms of overall money made as the markup they would've put on your fees they'll probably just transfer to the construction costs of the frame. However if the overall design is going to be tendered to multiple bidders and there's a chance that the contractor may not get the job, then that may pose other issues.
Either way, I'd start with a call to the contractor if you don't want to potentially sever the relationship. If this is a one-off project from the contractor and you don't care about what bridge is burnt, I'd just send the proposal.
Agree with jayrod12. If you're not worried about keeping the contractor happy, I don't see anything wrong (unethical) with your option #3. If you value the relationship with the contractor, I'd modify #3 - call and have an honest conversation with them and see how they're comfortable proceeding.
Disclosure. If you work for two different entities on the same project, you have to obtain concurrence from both that they are aware. Outside of that, no issue, since you will do your work independent of who pays the bill (I know that's what you would do, JAE!)
I once was in a similar situation but I had a sound relationship with contractor so the response was pretty obvious for me at the time. My option was:
4. Call the contractor and explain that you were called by the owner and asked to provide a proposal and DO NOT intend to do so.
Note that if you and the contractor get together and agree that one of you won't bid, that may be an ethical consideration in itself.
Does your cost depend on who you work for? In other words, did you give the same cost for the same services in both proposals?
If so, I'd say you work for the first party to sign your proposal. It sounds like both the owner and the contractor see value in hiring you directly.
You have no control over who the owner decides to work with or not work with. If the owner wants to hire you, you have no obligation to the contractor, and vice versa.
Your loyalty belongs to the party that hires you....be it the owner or the contractor.
Well I have no legal obligation to the contractor but the ethical dimension here is that the contractor introduced me to the owner, allowed me to do an initial investigation project for their facility as well.
The contractor, for his part, spent a huge amount of time working with the owner on developing a concept (schematic design) and pricing. Then the owner pulls the rug out and basically says to the contractor, "well thanks for all your free up front services but now we are going to hire the engineer directly and force you to bid against others to get this work."
In some sense, the contractor presumed (wrongly) that his up front services would be rewarded but that wasn't the case.
If your proposal would be the same, then I'd vote for #3: This gives the contractor the opportunity to remove the markup that they should not have put on your work and re-submit their proposal to match the one that you're sending.
If your proposal would be more, because sometimes going to bid might yield a different set of drawings on your part, then I'd just go with #1, though the owner might want some explanation.
I wouldn't consider #2, being averse to exclusivity.
You might want to look into your State's laws regarding Professional Engineering and Conflicts of Interest. From Nebraska Engineer and Architects Regulation Act Handbook:
5.2.1 The architect or professional engineer shall not accept compensation for their services from more than one party on a project unless the circumstances are fully disclosed to and agreed to (such disclosure and agreement to be in writing) by all interested parties.
zelgar - there isn't a conflict of interest as we've not contracted directly with either party yet, nor would we.
The question was more aimed at the issue of beginning work for a client when that client abandons the party that introduced you in the first place.
Were you paid for the project from the contractor? If so, it would be a conflict of interest to get paid again by the owner for the same design.
I was paid by the owner - through the contractor - for an initial investigation report.
Once the investigation revealed that another separate structure would be required, the contractor asked me for a proposal to design that new structure.
The owner then called me and asked me to give them the proposal for the new structure direct - and not through the contractor.
So there is no conflict of interest here - two separate projects - one client.
It's still one project, as the need for the new structure was based upon the original work you did for the contractor. Others seem to agree:
Quote (Ron on 22 Nov)
You seem to disagree, though
Quote (JAE on 27 Nov)
I think there is a legal issue in addition to the ethical one as the Conflict of Interest (CoI) portion of the rules would apply in this case, IMHO. If you're planning to cut out the contractor about the design of the new structure, I would contact a lawyer first to make certain that you're not in violation of the CoI regulations.
Seems to me the conflict can only exist if the contractor could also do the new work, even though they did sub the original work to you. It can certainly be perceived from the outside that you managed to bypass the contractor and cut them out of bidding on the new work. If the contractor cannot possibly bid on the work themselves, independent of you, then there is no conflict, per se. Nevertheless, full disclosure to the contractor would seem to be the most appropriate action.
TTFN (ta ta for now)
There is no conflict of interest.
There are two completely different "projects" so I'm not being paid by two entities on the same project.
One was a study of an existing roof structure currently supporting two mechanical units.
The report outlined the existing structure and showed its limitations.
No mention or reference to a new structure completely separate from the original structure.
The "second" project is about the design of a completely separate steel tower platform to support two completely new units.
I did not "cut out the contractor". The owner did.
I was hired to do a study - I did a study.
The contractor asked me to provide a proposal, separate from the study, to design a steel frame.
I gave him a proposal - he never signed it.
The owner then asked me for the same type of proposal to design the steel frame.
Currently I do not have any contract or agreement to either party to do anything more.
The conflict here is not one where I'd have a "conflicted interest" where my engineering judgement would possibly be compromised.
Nor is there something I'm doing to "cut out" or undermine the contractor.
Even if the contractor signed my proposal, I would be concurrently aware that the owner didn't intend on paying the contractor for my design anyway.
The ethical or moral dimension here is not one of conflict of interest - but perhaps more of social or business obligation.
If you were compensated by both the Owner and the Contractor for the Design of the Steel Frame, without it being fully disclosed and agreed to by all parties in writing, you have a Conflict of Interest. I feel this situation is very Black & White.
It's starts to get grayer, if only the Owner asked for your deign of the steel frame and is trying to cut out the Contractor for the future work, after you performed the initial Study.
Since this is a potential legal situation, I would suggest you consulting a layer about this.
Quote (zelgar)
I was NOT compensated by both. I've said that twice now. Only compensated ONCE for the REPORT/STUDY by the contractor through the owner.
Quote (zelgar)
I was asked by both the contractor and then the owner for a proposal for the design. Neither has signed either proposal yet.
The owner is NOT "cutting out the Contractor" in that the contractor can still bid the job - just won't get preferential treatment by being handed the project.
Quote (zelgar)
This is not a legal situation.
There is nothing illegal:
a) about a contractor asking me to provide them a proposal
b) about the owner asking me to provide them a proposal.
c) about me providing said proposals when I'm not under contract with anyone.
The question is almost more of a courtesy issue - the contractor introduced me to them. The contractor had provided free, marketing-like services to the owner by involving me, providing other mechanical reviews, and proposing certain options - all with the expectation (not legal obligation) that the owner would respond by continuing to offer the contractor the sole opportunity to provide all the mechanical design and equipment.
There is a hint of ethical issue with the owner in that they may have led the contractor to believe that they would honor such up-front free services with a relationship, not revealing that they ultimately would simply put the thing out for bid.
Maybe I'm missing something, but it appears that you've provided design drawings to both the Contractor and the Owner without getting paid? Based upon the Owner's actions, I would be afraid that even if he did use your design, that he wouldn't pay you for your work, unless I'm missing something (e.g., the drawings haven't been stamped).
In all of my posts, I was trying to make certain that there may be a Conflict of Interest if you were being compensated by both parties without full disclosure. I feel like things could get problematic if the Contractor does pay you for your original design and so does the Owner, especially if the Owner decides not to go with the Contractor.
Personally, I think full disclosure to the Contractor should have occurred when the Owner contacted you for design.
Quote (zelgar)
Sigh.
I guess I'm not being very clear here obviously.
There are no drawings, zelgar. I haven't performed any design.
I have NOT been contracted to design anything.
I've only been asked to provide proposals to do the design.
Only a report exists (the first "project").
The rest is just proposals sent out - neither of which have been accepted or signed by either the owner or the contractor.
The original question was whether to notify the contractor of the fact that the owner had asked us for a proposal similar to the one I'd already given the contractor.
It had to do with the nature of the ethics, or moral duty, of providing a second proposal to the owner and whether to communicate that fact to the contractor.
You keep talking about conflict of interest and there is none. That is not the subject of this situation at all.
There can be no conflict of interest if there is no interest (i.e. there's no standing agreement in existence)
Per both college ethics and the legal dept, we are legally and ethically obligated to clients from the moment we submit a quote to the time the quote is either rejected or the project completed, so I would concur that this is a conflict of interest.
I don't see the ethical or legal issues raised by other posters.
I think your response should be based upon your relationship with the Contractor, and what is best for your business moving forward. There may be other factors to which you are not aware that led the owner to modify the previously understood course of action. A discreet phone call to the contractor may help bring more light to the situation at hand.
Maybe I mistaken when I said drawings, but you've repeatedly indicated that you have provided proposals to both the Contractor and the Owner about the design of the new structure. I thought the proposals was the engineering design of the structure, not a contract to perform the design. I think part of the confusion was my misunderstanding your original post where you indicated that the Contractor presented your proposal (marked up by the Contractor) to the Owner.
I still feel that you should make a full disclosure with the Contractor that you were contacted with the Owner to submit a proposal for the new structure, since they requested a proposal from you first. As you indicated, you were concerned with ethics about the situation, but you also need to evaluate if there are any legal ramifications. Since your profile indicated you're from Nebraska, I checked their website to see the rules, but only was able to find Nebraska Engineer and Architects Regulation Act Handbook. The section concerning Conflict of Interest seemed to possibly apply to this case, as I have been trying to convey.
Finally, since it appeared that after the study was complete it was determined that the design of a new structure is needed. One could make the argument that the design of the new structure is a continuation of the original study, which is why I thought you might want to get legal advice. If the Owner ends up getting you to do toe design of the new structure and the if the Contractor doesn't get the project, the disgruntled Contractor may file a complaint against you to the State Board. Diffusing the possibility of a complaint by having full disclosure now may prevent any complaints later, or talk with a lawyer and see what they think.
Quote (zelgar)
A proposal is simply me saying to someone - I will do x, y, and z for this many dollars assuming you agree to the terms and conditions of our agreement.
Quote (zelgar)
I agree 100%
Quote (zelgar)
I disagree 100%.
The study was simply a scope/fee/agreement to study.
The study resulted in the owner being informed that a separate steel frame was a good idea and highly recommended.
But my study does NOT guarantee me getting a "continuation of the project".
I hope you see the subtlety here: If I write my report suggesting that the owner MUST continue to hire me to do the design, that is a true conflict of interest.
My report/study should always be treated as a totally independent effort on my part - not contingent upon me getting more work from the owner.
Quote (zelgar)
....the disgruntled Contractor may file a complaint against you to the State Board.
If I do contact the contractor (which I actually did do) and notify them that...cough cough...the owner asked me for a proposal - essentially informing the contractor that it looks like the owner wasn't going to use them exclusively for the work - then I've been fair, open, communicative, and honest in all my dealings. There's nothing that I did that would bother our state board.
Quote (CWB1)
"ethically obligated"
OK I'd agree that I"m always ethically obligated - but you must define what exactly we are obligated to do.
I submitted a quote to the contractor to provide engineering services.
Does that man I'm obligated for all eternity to never do work for the original owner? I think not.
I am obligated to communicate to the contractor that my proposal to them was now null and void.
Anyone, at any time, can rescind a proposal.
A proposal is NOT an agreement. It is NOT a contract. I can write a proposal, the other party can sign it - but I can decide then NOT to sign.
No agreement - no relationship - and no conflict of interest.
I might push your argument 180 degrees here.
If I get a signed agreement back from the contractor, knowing full well that the owner wasn't going to hire the contractor or use my work through the contractor, and I then proceed to do the design work and charge the contractor - THAT would be unethical.
What my final thoughts are is that:
1. I notify the contractor that the owner has chosen to hire the design directly.
2. I notify the contractor that the owner will put the work out for competitive bidding.
3. I respond to the contractor's questions and offer full disclosure that I intend to give the owner a proposal.
4. Even though it will probably hurt my relationship with the contractor - I have to take that "hurt".
5. I can and will commend and speak highly of the contractor to the owner.
JAE, sounds like the owner put you in a tough spot and I would hope the contractor would recognize that this situation is really on the owner and not hold it against you. I think your approach is about as ethical as you can be while still trying to run a business and bring in work. I think as long as you are respectful and transparent with all parties, that's what's most important. The contractor might feel somewhat betrayed initially, but in the long run they will remember that you treated them with respect.
bones206 - very good summary - agree with all of what you posted.
We are ethically obligated not to compete against clients. In your case, the contractor is your client. Submitting a quote to the end-customer directly, even if its for a customer-proposed separation of design & build could be considered competing as the contractor has potential to lose business while you gain.
No, that's why quotes have end dates.
You'd better consult the attorneys on that one. I have always been told that unless the client agrees to release you, you are tied to them legally until the quote expires or they choose a competitor as a legal expectation of having responded to a RFQ with a quote.
No, until I receive a signed agreement there is no agreement or obligation.
An outstanding proposal is not a contractual obligation.
I am free to rescind a proposal anytime.
White Paper: Industrial Control Basics: Contactors
A contactor is an electrical device used for switching an electrical circuit on or off. Considered to be a special type of relay, contactors are used in applications with higher current carrying capacity, while relays are used for lower current applications. Download Now
Research Report: State of IoT Adoption in Product Development 2019
This research report, based on a survey of 234 product development professionals, examines the current state of Internet of Things (IoT) adoption by product design teams, its perceived importance, and what features and capabilities teams consider important when making decision about adding IoT functionality to their products. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
