Contact US
Case Hardened in place of Hard Faced
We have requirement of Plug CS body with SS trim and hard faced Plug and Body Seating surface. However, offer received from vendor is Case hardened Plug, I want expert comments on this issue if case hardened is good replacement for hard facing.
Thanks in advance.
RE: Case Hardened in place of Hard Faced
Obviously on a general basis, hardfacing is a more costly process and can supply a face with much more resistant materials than a case hardening process. The processes and end properties are in general far from equal.
Wikipedia:
Case-hardening or surface hardening is the process of hardening the surface of a metal object while allowing the metal deeper underneath to remain soft, thus forming a thin layer of harder metal (called the "case") at the surface. For iron or steel with low carbon content, which has poor to no hardenability of its own, the case-hardening process involves infusing additional carbon or nitrogen into the surface layer.
Hardfacing is a metalworking process where harder or tougher material is applied to a base metal. It is welded to the base material, and generally takes the form of specialized electrodes for arc welding or filler rod for oxyacetylene and TIG welding. Powder metal alloys are used in (PTA) also called Powder plasma welding system and Thermal spray processes like HVOF, Plasma spray, Spray and Fuse, etc.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
