Welding of ASTM A671 CB60 and CB70 material
The header pipe is A671 CB60 material; we need to weld reinforcement pad to this, however, due to non availability of CB60 material, contractor is proposing CB70 material. I dont see much issue as both CB60 and CB70 have the same P nos; however, not sure whether to indicate any specific thing apart from this.
RE: Welding of ASTM A671 CB60 and CB70 material
This reference indicates CB60 is fabricated from A515 Grade 60, while CB70 is fabricated from A515 Grade 70.
Both are weldable and I would say you are safe in permitting this substitution, provided your welding procedure specifications cover the change in ASME IX group number.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
