Word Photo Album - insert new table
justhumm
I'm trying to put together a photo album macro for Word.
I basically have the general process for the first loop, but after that, instead of inserting a completely new table, everything I've tried either overwrites the first table, nests the new rows inside the first table, or adds new rows (with bad formatting) the the first table.
I'm obviously not exiting out of the first table properly, but can't figure out how...any suggestions?
Thanks!
Code:
Format Page
Select Folder
For each image in folder
[indent]Insert New (2x1) Table[/indent]
[indent]Exit out of Table[/indent]
Code:
Option Explicit
Dim oDoc As Word.Document
Dim oSec As Word.Section
Dim rng As Word.Range
Dim xFileDialog As FileDialog
Dim xPath, xFile As Variant
Dim str As String
Dim i As Integer, j As Integer, k As Integer, intTables As Integer
Sub PictureAlbum()
' [URL unfurl="true"]https://www.extendoffice.com/documents/word/5451-insert-picture-with-filename-in-word.html[/URL]
    Set oDoc = ActiveDocument
    Call SetPage
    On Error Resume Next
    Set xFileDialog = Application.FileDialog(msoFileDialogFolderPicker)
    intTables = 0   ' set initial value
    If xFileDialog.Show = -1 Then
        xPath = xFileDialog.SelectedItems.Item(1)
        If xPath <> "" Then
            xFile = Dir(xPath & "\*.*")
            Do While xFile <> ""
                If UCase(Right(xFile, 3)) = "PNG" Or _
                    UCase(Right(xFile, 3)) = "TIF" Or _
                    UCase(Right(xFile, 3)) = "JPG" Or _
                    UCase(Right(xFile, 3)) = "GIF" Or _
                    UCase(Right(xFile, 3)) = "BMP" Then
                    Call AddTable
                    oDoc.Tables(intTables).Cell(1, 1).Select
                    With Selection
                        .InlineShapes.AddPicture xPath & "\" & xFile, False, True
                        .InsertAfter vbCrLf
                        .MoveDown wdLine
                    End With
                    oDoc.Tables(intTables).Cell(2, 1).Select
                    With Selection
                        .Text = xFile & Chr(10)
                        .MoveDown wdLine
                    End With
                    ' Exit out of table
                    oDoc.Tables(intTables).Select
                    With Selection
                        .Collapse WdCollapseDirection.wdCollapseEnd
                    End With
                End If
                xFile = Dir()
            Loop
        End If
    End If
    'Application.Selection.EndOf
'    For Each oSec In oDoc.Sections
'        Set rng = oSec.Headers(Word.WdHeaderFooterIndex.wdHeaderFooterPrimary).Range
'        AddHeaderToRange rng
'    Next oSec
End Sub
Private Sub AddTable()
    ActiveDocument.Tables.Add Range:=Selection.Range, _
        NumRows:=2, NumColumns:=1, _
        DefaultTableBehavior:=wdWord9TableBehavior, AutoFitBehavior:=wdAutoFitFixed
    ' intTables = oDoc.Tables.Count
    intTables = intTables + 1
    With Selection
        If .Style <> "Table Grid" Then
            .Style = "Table Grid"
        End If
        .Columns.PreferredWidthType = wdPreferredWidthPoints
        .Columns.PreferredWidth = InchesToPoints(8.5)
        .ParagraphFormat.Alignment = wdAlignParagraphCenter
        .Rows.AllowBreakAcrossPages = False
        .Rows.HeightRule = wdRowHeightExactly
        .Rows(1).Height = InchesToPoints(6)
        .Rows(2).Height = InchesToPoints(0.75)
    End With
End Sub
Nevermind...this needs to be cleaned up, but basically does what I want...
I needed to add in a new paragraph (or two) after the table.
Code:
Option Explicit
Dim str As String
Sub PictureAlbum()
' [URL unfurl="true"]https://www.extendoffice.com/documents/word/5451-insert-picture-with-filename-in-word.html'[/URL]
' [URL unfurl="true"]https://stackoverflow.com/questions/34794656/vba-insert-multiple-table-in-documnet[/URL]
    Call SetPage
        If xPath <> "" Then
                    Call AddTable
                    With Selection
                        .InsertAfter vbCrLf
                        .MoveDown wdLine
                    End With
                    With Selection
                        .MoveDown wdLine
                    End With
                    ' Exit out of table
                    With Selection
                    End With
                End If
                xFile = Dir()
            Loop
        End If
    End If
End Sub
    oDoc.Paragraphs.Add
    oDoc.Paragraphs.Last.Range.Select
    With Selection
        End If
        .Rows(1).Height = InchesToPoints(5.875)
        .Rows(2).Height = InchesToPoints(0.625)
    End With
End Sub
Private Sub SetPage()
    With oDoc.PageSetup
        .LineNumbering.Active = False
        .PageWidth = InchesToPoints(8.5)
        .PageHeight = InchesToPoints(11)
        .Orientation = wdOrientLandscape
        .TopMargin = InchesToPoints(0.75)
        .BottomMargin = InchesToPoints(0.75)
        .LeftMargin = InchesToPoints(0.75)
        .RightMargin = InchesToPoints(0.5)
        .Gutter = InchesToPoints(0)
        .GutterPos = wdGutterPosLeft
        .HeaderDistance = InchesToPoints(0.5)
        .FooterDistance = InchesToPoints(0.5)
        .TwoPagesOnOne = False
        .BookFoldPrinting = False
        .BookFoldRevPrinting = False
        .BookFoldPrintingSheets = 1
    End With
    oDoc.Select
    With Selection
        .Font.Name = "calibri"
        .Font.Size = 11
    End With
End Sub
