how to define the K-value for the connection between a pipe and sphere bottle
jichai
CA
Hi all, I tried to model the connection between a pipe and sphere bottle in a Recip compressor package, but don't know how to define the k-value for this fitting?
Can anyone give some hints? Thanks
Are you referring to the flexibility of the bottle connection or the accoustic resonance condition?
Hi hacksaw, thanks for the reply. yes, the sphere bottle is used for pulsation control, and I am trying to model the connection between the bottle and the pipes. No idea how much the K value I should define for it.
Hi GregLocock, thanks for the reply, and where should I go for the acoustics questions?
Good, we've established that it's acoustic and it sounds as if you are talking about a Helmholtz resonator.
In the normal equation k is the stiffness of the gas spring (the big volume) and m is the mass of the slug of air in the neck.
Wiki is your friend.
Cheers
Greg Locock
Or are you referring to the loss coefficient for the fitting?
