Catia V5 Macro to create Cylinders using Sweep and center curves 1
Catalin_2018
DE
Hello everybody,
I'm writing here in order to ask for your help. I'm not a good programmer! :)
My request is based to post: thread560-332713
In my case I have next structure:
Input: a geometrical set which contains a lot of lines (created with macro from the post mentioned above) - more than 2000 lines
Output: a new geometrical set that contain Sweeps (profile type: circle) using each line as "Center curve" and a "Radius" defined into macro.
My input:
Thank you in advance for your support, I really appreciate your work!
Kind regards,
Catalin
here is a piece of code that does the same thing
Option Explicit
Dim i As Integer
Dim mySel As Selection
Dim myPrt As Part
Dim myHB As HybridBody
Dim mySurfRef, myPointRef, myLineRef As Reference
Dim HS_Factory As HybridShapeFactory
Dim HS_Surf As HybridShapeSurfaceExplicit
Dim nLine As HybridShapeLineNormal
Dim myDir As HybridShapeDirection
Dim myCyl As HybridShapeCylinder
Sub CATMain()
Set myPrt = CATIA.ActiveDocument.Part
'this set must contain only one surface and n points
Set myHB = myPrt.HybridBodies.Item("Geometrical Set.1")
Set HS_Factory = myPrt.HybridShapeFactory
Set mySel = CATIA.ActiveDocument.Selection
'Search for GSD lines and points (the order is important)
mySel.Search "('Generative Shape Design'.Surface + 'Generative Shape Design'.Point);sel"
'In the selection we have the surface as the first item
Set mySurfRef = myPrt.CreateReferenceFromObject(mySel.Item(1).Value)
For i = 2 To mySel.Count
'create reference from point and use it later in the cylinder creation
Set myPointRef = myPrt.CreateReferenceFromObject(mySel.Item(i).Value)
'make the normal line
Set nLine = HS_Factory.AddNewLineNormal(mySurfRef, myPointRef, -15#, 15#, False)
myHB.AppendHybridShape nLine
'Give line a name
nLine.Name = "nLine-" & i - 1
myPrt.InWorkObject = nLine
'make a reference from this line because we use it as direction
Set myLineRef = myPrt.CreateReferenceFromObject(nLine)
Set myDir = HS_Factory.AddNewDirection(myLineRef)
Set myCyl = HS_Factory.AddNewCylinder(myPointRef, 2#, 15#, 15#, myDir)
'make the cylinder and name it
myHB.AppendHybridShape myCyl
myCyl.Name = "myCyl-" & i - 1
myPrt.InWorkObject = myCyl
myPrt.Update
Set myCyl = Nothing
Set myDir = Nothing
Set myLineRef = Nothing
Set nLine = Nothing
Set myPointRef = Nothing
Next i
mySel.Clear
Set mySurfRef = Nothing
Set mySel = Nothing
Set HS_Factory = Nothing
Set myHB = Nothing
Set myPrt = Nothing
End Sub
Thank you very much John! ;)
You saved my time!
I adapted a little your code because of some errors:
Option Explicit
Dim i As Integer
Dim myPrt As Part
Sub CATMain()
Set nLine = HS_Factory.AddNewLineNormal(mySurfRef, myPointRef, -15, 15, False)
'Give line a name
Set myCyl = HS_Factory.AddNewCylinder(myPointRef, 2, 15, 15, myDir)
myPrt.Update
Set myCyl = Nothing
Set myDir = Nothing
Set nLine = Nothing
Next 'i
mySel.Clear
Set mySel = Nothing
Set myHB = Nothing
Set myPrt = Nothing
End Sub
Kind regards!
Catalin
