Contact US
Standard clearance for Cage and plug
Dear Engineer,
How are you mate?
by the way if you have reference for standard clearance for Cage and plug, mate?
looking forward to hear from you.
Rio
RE: Standard clearance for Cage and plug
To my knowledge there is no standard distance between cage and plug. As this is a type of valve often used in different processes, both regarding chemical applications, fluid properties, temperatures and applications,I suspect this is factory specified based on experience, and not freely given away.
Hi...
There is no such a standard for the defining clearances between Cage and Plug.
Thermal expansion calculation will be used for defining the max and min clearances.
below formula is general formula. if you have max min values of Cage IDs then you can find Max. clearance as well Min. Clearance. Based on the clearances you can arrive OD of Plug.
Clearance = Cage ID * Material Expansion * (Max temperature - Min temperature)
Plug OD = Cage ID - Clearance
the link provided here is for list of materials along with the material expansions based on the temperature.
https://www.engineeringtoolbox.com/thermal-expansi...
Dinu...
There are no secrets to success. It is the result of preparation, hard work, and learning from failure.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
