Definition of "Root" Valve
I have come across the term "Root" valve on a number of different occasion and I still don't have an accurate understanding of when the term should be used.
I originally thought that isolation valves for instruments (e.g. pressure gauge) was called a root valve. However I have also seen someone refer to the first isolation valve on a sub-branch from a larger header referred to as a root valve - I am not sure if this is a common term in Oil and Gas?
Does anyone have any feedback on this?
RE: Definition of "Root" Valve
The answer is "Yes" to all the above.
It is used by different companies for whatever, wherever and however they (the company as a whole or some individual in the company) choose. They just need to define it.
It is important to understand that the term "Root" valve is a function, NOT a valve Type, It is any valve type used for "That" purpose, normally consistent with all other valve types from that commodity's Piping Material Line Class Specification.
Sometimes its possible to do all the right things and still get bad results
I've been working now in oil and gas systems for over 30 years and never heard anyone ever refer to a valve as a "root" valve, but your logic makes sense and like pennpiper says (and he has more experience than me in plant design) it could be different things to different people.
I would struggle to say this is a "common term" though.....
https://en.wikipedia.org/wiki/Snipe_hunt
But yes, "root valve" is just a term used as to indicate the first isolation valve following a take-off from a larger header. For me, the term has been used for vents, drains, and instrumentation. I have also heard the term used for equipment isolation valves as well, although I'm not sure if that is as common or if it is just something I hear where I am.
PIP PNC00005 "Design of ASME B31.3 Metallic Piping Systems" states:
3.3.3.6 Small Piping Root Valves
root valve located as close as feasible to the run.
diameter (except for insulated lines) measured from the far end
of the boss to the near end of the valve.
main pipe run and the root valve.
3.8.7 Utility Stations
from a main header or auxiliary header that cannot be taken out of
service without shutting down a complete processing unit or
operating facility.
"Thinking is the hardest work there is, which is probably the reason why so few engage in it."
-Henry Ford
https://www.google.com/search?q=root+valve&cli...
CR
