Which tolerances apply on large dimensions?
tariq89
OM
Dear all,
ISO 2768 describes the general tolerances for dimensions and geometry:
nevertheless; it gives the tolerances up to specific length, which code is valid for larger dimensions i.e. above 10 meters?
Thank you all in advance
One standard you could use (though it's for welded items, it could be used for underwelded items as well) is ISO 13920.
