Adams/Car Truck Simulation
Fred88
Automotive
IT
Hi everybody!
Is there someone skilled with Adamms/Car Simulation? I'm manipulating a truck assembly (tractor+semitrailer) in Adams/Car environment adding a device able to apply forces on a test tire (to be fitted under the trailer rigid body). The simulation aborted several times: maybe there's an error with the "mounting part" used to link the trailer body subsystem to the tire test rig one. I set the "minor role" for the subsystem as "any" and "analysis" for the "major role" but the two subsystems seem not to "talk" each other!!! Should I create the tire test rig directly on the rigid trailer body switching in Adams/View without creating a new Template in Adams/Car?
Thank you all
On the plus side there is an MSC ADAMS forum on this site
On the minus side I scarcely use CAR and have never used TRUCK, and I seem to be the only contributor to that forum recently.
Have you tried MSC support directly, or their user forums, which are pretty good?
Cheers
Greg Locock
Thank you so much Greg
