Staad & Concrete Analysis + Design - Stiffness?
I understand that Staad uses the moment distribution method for beams, a stiffness matrix for frames, and FEM for plates.
I'm trying to better understand how Staad works for concrete.
My core Concrete questions are:
1) How does Staad arrive at it's default assumed isotropic Young's modulus of 435,600 ksf? Is this a composite value that assumes some percentage of steel is in the concrete?
2) It appears, that Staad uses the full 100% moment of inertia for concrete sections, but I have heard talk that the software makes adjustments by assuming the concrete is cracked and uses a reduced MOI. Is this true?
The company I work for pays for all sorts of training and support from Bentley as part of our Staad/Microstation license, but I can't make heads or tails of their website. I have looked on Bentley's Connection Client & "LearnServer"; along with various other product support pages. Their website is incredibly confusing though.
Thanks!
RE: Staad & Concrete Analysis + Design - Stiffness?
I'm not sure. I use a user input value (calculated by the code equation).
Whenever I use reinforced concrete members in STAAD, I use user defined, "general" member properties. That lets you define the moment of inertia and other properties.
For slabs, I adjust the Elastic constant to reflect the cracked properties. (You can several different sets of material properties in the same model, for the same material.)
White Paper: Industrial Control Basics: Contactors
A contactor is an electrical device used for switching an electrical circuit on or off. Considered to be a special type of relay, contactors are used in applications with higher current carrying capacity, while relays are used for lower current applications. Download Now
Research Report: State of IoT Adoption in Product Development 2019
This research report, based on a survey of 234 product development professionals, examines the current state of Internet of Things (IoT) adoption by product design teams, its perceived importance, and what features and capabilities teams consider important when making decision about adding IoT functionality to their products. Download Now
Research Report: Augmented Reality for Maintenance, Repair and Overhaul (MRO)
The term Industry 4.0 denotes a cluster of technologies that’s poised to fundamentally reshape manufacturing and bring about a new industrial revolution. These include 3D printing (AM), the Industrial Internet of Things (IIoT), artificial intelligence (AI) and mixed reality technologies, more commonly known as virtual reality (VR) and augmented reality (AR). Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
